Hi everybody,
I am trying to implement a window that shows how long it took for each layer, in your map view, to draw. Is there a place in the SDK where I can see this time?
Tim
Hi Tim,
Are you aware of PerTools - could work for you.
PerfTools for ArcGIS Pro
Cheers,
Mark
This is even better thanks so much Mark.
There is an equivalent for ArcMap as well. We use it all the time - has proved very valuable for performance tuning our mxd projects that are published to services.
The scripting also looks interesting - if you are into coding, this could be valuable.
Do you know where I can download the ArcGIS Desktop tool?
