I am just learning the Python API so bear with me. A strange text box appears before the password prompt (appears twice). Not sure what is causing it.
I enter the password four times
Hi Amy,
Can you attach a copy of the Jupyter so I can test the issue on my end?
Have you tried restarting the Python kernel?
-Josh
Here you go. last one was not correct. I have tried restarting the Kernel. Also, i use the same username for both target usernames, not sure why it asks for that twice.
Amy,
The text boxes are a result of calling getpass() twice. The getpass() function prompts for user input without revealing it in plaintext. If you don't mind me asking, what is the goal of this script? Do you wish to authenticate to both the target and source portal anonymously? If so, there is no need to use the getpass() function.
Josh
I am trying to clone portal 10.5.1 to 10.7.1
link: Jupyter Notebook
