I have used an ESRI template which was downloaded from GitHub and I want (a) to change the dimensions or position of the frame which includes the title and (d) to add more widgets.
To answer part of your second question change
floatingtheme/widgets/FloatingHeader/css/style.css
Change the % to any you want. Also the max-width calc the theme is set up to -60px from 100% but if you want it to cover the whole page delete the line.
Change line 18& 19
jimu-widget-floatingheader { width: 100% !important; max-width: calc(100% - 60px);
Barbara,
What template did you download from Github?
Hello Rickey,
I downloaded this one..
EsriCanada/WAB-FloatingTheme · GitHub
Do you have the developer edition downloaded or did you create your app on AGO?
I have the developer edition.
Have you moved the downloaded theme into the theme folder in the web app builder files?
Have you set up the developer edition on a server?
Yes and yes and I have already made my first app. And now I want to make changes... to many things concerning the data and symbology and also to the theme and add some more widgets.
ArcGIS Web Application http://webgis-mfk.geol.uoa.gr/Life_Oiti/
What I do when I want to make changes to an app that I have already downloaded and published is, go back into developer and make changes. I then re-download and publish to my server replacing all files of the working app with the new ones.
If it is a small change I sometimes make the changes to the app in developer then re-download and copy over the changes into specific files in the published app. (this is very dangerous if you don't know what you are doing)
I Know all that.. My problem is that I don't know how to make the changes I want to the theme
Ask a specific question and we will try to help you.
As I have already mention in my post, I have used this specific ESRI template which was downloaded from GitHub and I want (a) to change the dimensions or position of the frame which includes the title and a logo and (b) to add more widget positions.
More specific I want the frame's width to be as long as the map. Also I want to change the logo's properties (opasity, width).
Finally, with this theme I got 5 "empty" positions of widgets. I want to know how to make more of them.
To answer your second question,
Add to line 65:
FloatingTheme/laouts/horizontal/config.json
, { "position": { "left": 260, "bottom": 10 } }
I have not tried this since I don't have 1.2 installed yet.
