FMEとRoads & Highwaysをお持ちの方のために、Iowa DOTは複数のR&Hウェブサービスを組み合わせてエンドユーザーが位置データを簡単に変換できるカスタムFMEトランスフォーマーとウェブサービス(SkyFireと呼ばれる)を開発しました。 私たちの古いLRSには、私のチームが開発したJetFireというAPIがありました(添付のドキュメント参照、まもなく廃止予定)<\/SPAN>SkyFire APIコールの例 <\/SPAN>https:\/\/fme.iowadot.gov\/fmedatastreaming\/SkyFire\/...<\/A> <\/SPAN><\/SPAN>FMEをお持ちで詳細を知りたい方は、私にメールをいただければ、私たちが持っているものを共有できます。 <\/SPAN><\/P><\/P>ESRI workflow managerで同様のことを行ったことがある方は、ぜひどんなことをされたか見せてください。私たちのArcGIS Serverスタック上で同様のジオプロセシングサービスを立ち上げたいと考えています。R&Hサービスを活用して素晴らしいことをしている組織の事例を紹介するウェビナーを開催するのも良いかもしれません。<\/SPAN><\/P><\/BODY><\/HTML>
Eric, we'd be interested in seeing what you have done. Didn't notice your email in profile. Could you please shoot me a message at some point to discuss; scott.fierro@dot.ohio.gov Thanks
Sure will once I get a list of those interested. Funny you cant see my email in the profile, I will check that eric.abrams@iowadot.us.
Thanks for sharing this Eric. This is good stuff. I'd also like to make the case for geoprocessing (GP) services for these kinds of solutions. The biggest benefit is that you have a COTS client with the Web AppBuilder Geoprocessing widget that you can deploy without writing any code. Using a WAB application, people could execute these functions from their phone or any other device. If authored correctly geoprocessing services can have very good performance and can access all of your GIS data. Check out this (very simple) GP service I made for doing offsets with MassDOT data: Execute Task (FindMassDOTOffset). As you can see this GP service performs pretty well. To get the best performance with GP services check out the help doc here: Performance tips for geoprocessing services—Documentation | ArcGIS Enterprise.
We started with a GP service but had performance issues. We did not take the time to do a deep dive on why it was slow; could of been our ignorance. After you and I talked last week, the challenge is on to create a complex GP service and see if we can get the same or similar results. GP services gives us a better integration with Web App Builder, which is needed. But there are some special things our service does that a GP service may not be able to accomplish, stay tuned. We will hit you up for a starting sample.
