Survey123の「geopoint」機能を使用する際、GPSで現在地を中心にしている場合、ラベル付きのポイントがある自分のマップを読み込むことは可能ですか?<\/P><\/BODY><\/HTML>
Thanks Derek.
Hi Peter,
It is possible to side load a map to use as a basemap, typically for offline use. I suppose the basemap could contain points with labels, but they will not work dynamically with a GPS or anything.
Prepare basemaps for offline use—Survey123 for ArcGIS | ArcGIS
Hope this helps,
