<appSettings> <add key="OutputPath" value="C:\\arcgisserver\\arcgisoutput\\" /> <add key="OutputUrl" value="http://www.[your domain]/arcgisoutput/" /> </appSettings>
//configure custom PrintableLayer esri.config.defaults.io.proxyUrl = "http://www.maps.ccgisc.org/proxy.ashx"; var layer = new my.PrintableLayer("http://www.maps.ccgisc.org/MergeAndOutput.ashx", { layers:appState.map.layers, extent: new esri.geometry.Extent(appState.map.extent) });
printingHiddenFrame.src = "../hiddenframe.html";
[NullReferenceException]: Object reference not set to an instance of an object. at MergeAndOutput.BlendNoSave(Graphics baseGraphics, Bitmap topimg, Double transparency) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 303 at MergeAndOutput.Blend(Bitmap baseimg, Bitmap topimg, Double transparency, String output, Int32 width, Int32 height) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 250 at MergeAndOutput.Blend(Dictionary`2 dict) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 208 at MergeAndOutput.ProcessRequest(HttpContext context) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 28 at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
This was working fine for us @ 9.3.1; however, upon upgrading to AGS 10 it will not print if we use our aerials layer. I am getting a 500 internal server error when the aerials are printed. All other layers (basemap, etc) print fine.Here is the error output (via Firebug): [NullReferenceException]: Object reference not set to an instance of an object. at MergeAndOutput.BlendNoSave(Graphics baseGraphics, Bitmap topimg, Double transparency) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 303 at MergeAndOutput.Blend(Bitmap baseimg, Bitmap topimg, Double transparency, String output, Int32 width, Int32 height) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 250 at MergeAndOutput.Blend(Dictionary`2 dict) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 208 at MergeAndOutput.ProcessRequest(HttpContext context) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 28 at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)Any ideas?
