Not sure if this suddenly started happening at version 2.0.xyz of Survey 123, but I've just noticed that signature images are clipped in the submitted data. Attached is a copy of one of MY signatures from the ArcGIS Online feature service.
Has there been a change to signatures?
Hi Jaime,
We're aware of this issue; we are planning to address it in a future release of Survey123
In the meantime, is there a way to install an older version of Survey123 on IOS (iphone)? Or is there a work-around so that the signatures are not clipped when the survey is submitted? We have an application that we are testing, but without the signature, it will not be a successful test.
Hi Jamie,
My apologies, there isn't a way to downgrade an application.
Any idea on when this fix will be made? Collecting signatures is very important for our surveys.
Hi Chris,
This will be fixed in 2.3, which we are targeting for July after the User's Conference.
Hi James - it appears that we still have the issue of clipping signatures in the new update (2.3.29). The signatures are shifted to the upper left when we save the survey to drafts. We are using iOS (iPhones and iPads) to collect the data.
Hi Christopher
This issue has been partially fixed in that signatures are not cropped on submission of a survey. However there is still a bug where the signatures are cropped on re-load (e.g. re-opening a survey from drafts or the sent box) and sending. We have a fix for this other issue and intend to make it available in the next release.
HI Johnathan - it looks like this fix has not been pushed yet. Can you confirm when the clipping upon saving will be fixed?
Chris
Hi Christopher - this issue has been fully addressed. Please provide details of what you are seeing, on what version of the app and on what device.
Thanks
John
Hi Jonathan - We are using v. 2.3.29 of Survey123 and v. 2.5.44 for SurveyConnect. For field collection, we are using iOS devices (iPad Pro and iPhones).
If a signature is collected and then the survey saved "Save this survey in Drafts", the signature image is shifted/zoomed in to the left of the original signature when the survey is reloaded from drafts. See attached photographs for the differences between the two.
Initial Signature:
"Saved" signature:
Hi Christopher - please update to the latest version of the native app (2.5) in order to access the fix.
