Philip.Wilson-esristaff . Your help is appreciated as always.
You could go with something like this if you want to submit data for all students in one shot:
This will create a layer for the class, and a related table for students. Use the plus button in the repeat to add data for the next student.
When using a repeat, you can even use aggregate functions. For example, you can get the max, min, average of the weight, height and scores for the class. More info at: Repeats—Survey123 for ArcGIS | Documentation
Using relevant statements to hide/show questions will not work in your case because when a question is not relevant Survey123 will always send null values for it.
Bellow is the sample file
Below is what I am trying to do. I want the question "Student information details" to popup every time I click on each student's name instead of below all students' names.
Once I submit survey all students' information is sent at once.
Hi Jules
Could you please provide your XLSForm and a bit more detail (perhaps as an example) on what you're hoping to achieve? You can attach files to your post using the 'advanced editor'.
Thank you,
Jim
