Is it possible to update an ArcGIS Online map to be offline enabled strictly through ArcGIS API fro Python? I can't find anything that mentions it in the user docs for ArcGIS Mapping Module arcgis.mapping module — arcgis 1.4.0 documentation .
Currently I have to enable this by hand under map "Settings" and "Web Map Settings" then "Offline Mode"
This is currently being developed and will be available in the next version of the API. This will be exposed off the `WebMap` object in the `arcgis.mapping` module.
Hi Atma, Thanks for the reply. Good to know that the functionality is coming.
Hi Atma, any update on this functionality?
Hello Ryan Slevin, yes, we added this functionality a while back. You can read more about it here: Managing offline map areas | ArcGIS for Developers and see the API ref doc here: arcgis.mapping module — arcgis 1.5.2 documentation
