According to https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns.htm, I can use body::esri:style to change the background colour or border colour for my groups. This works when I choose to either change the background colour or the border colour. My question is, is it possible to change both background colour and border colour for a single group?
Hi Ada,
It is possible to apply both backgroundColor and borderColor in the body::esri:style column for a Group be separating the parameters with a space. For example:
backgroundColor="red" borderColor="blue"
Thanks! I can't believe I didn't try a space. Did ',' and ';' instead.
What about just one cell or group of cells in a grid? It seems like you can only do groups or repeats.
It also seems like border will not work in nested groups or repeats.
thanks
Bump. Needing this today again. Thanks
hi! this still doesn't have a solution does it? I would like to had a background color to just a column in a grid.
Confirming that border with a nested group still doesn't work
