I've seen discussion online for an "Assign River Order" attribute tool with ArcHydro, but I can't seem to find it. Can Someone help me out? It's exactly what I need.
Are they referencing the Stream Order function in Spatial Analyst instead? Will this accomplish what you need?
Stream Order (Spatial Analyst)
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Chris Donohue, GISP
This is where I encountered it https://community.esri.com/message/402971#402971
--> Christine: "You can try the geoprocessing tool Assign River Order
located in the Arc Hydro Tools toolbox in the Attributes Tools toolset."
I want to assign strahler orders to a vector network. The stream order tool
from spatial analyst > hydrology only calculates for rasters.
Jeremy
There is an older GeoNet thread where users expressed similar issues with not finding the tool in ArcHydro:
Stream Order (Strahler) and Flow Direction
The answer apparently is that it can be found at:
Zichuan Ye
(1) to to assign river order, you can use Assign River Order tool of ArcHydroToolbox (Toolboxes\System Toolboxes\Arc Hydro Tools.tbx\Attribute Tools).
Based on what is posted in the thread, it appears that one has to run it from the Toolbox directly. It is not on the ArcHydro pulldowns. (I don't have ArcHydro to check).
Found it! Figured it would have been in the toolbar.
Thanks!
No problem.
If you can, mark the solution as the "Correct Answer" so others who do a search on this will see that a solution was found.
