I have published a survey as Public.
I now have a feature layer and a form for the survey.
How do I get the public to be able to fill in the survey form?
Thanks.
Please go to Survey123 for ArcGIS | ArcGIS for the most recent versions.
Hi John,
Go to the 'Collaborate' page for your survey at survey123.arcgis.com - you'll find a link that can be given to people. If the survey was created via the Survey123 website, there will be a web link and a link to open in the field app (phone app). If you created the survey using Survey123 Connect, you'll find only the link to the field app. There is a new web form in Beta that can handle the more complex forms authored in Survey123 Connect. To access the beta web form, open the form in Survey123 Connect and click on the globe button; it has an option to 'Open in web app'. Click that, and the form will load in a browser.
On the field app links, we are finding some issues opening the form on Android devices; we've found the best experience is to create web page with a hyperlink. We will be implementing that in a future update of Survey123, though for now you would need to create the web page yourself.
Thanks for the reply James.
I created my survey using Survey123 Connect for ArcGIS and published it to ArcGIS online.
I don't seem to have a collaborate tab?
You should be able to get to the collaborate tab either by going to the survey123.arcgis.com website directly or by opening the survey in preview mode in Survey123 Connect, clicking on the globe icon, and selecting 'Manage in the Survey123 website'.
James I can see neither Manage no Collaborate
When I click on the globe in connect it opens the survey in ArcGIS online and there are 3 tabs, namely, Overview, Usage, Settings.
That sounds like you clicked on the 'View item details in your ArcGIS organization' button. Just to confirm, you are using a recent version of Survey123 (1.6 or higher)? You should see a menu that looks like this (the top link was added in 1.10):
I've version 1.5.35 .. obviously the problem
were can I download a version that I can create public surveys?
