Is there a way to Change the formal Settings in the Report of a Survey?
Such as:
- Display only a few of the questions from the Survey
- Change the font,size, line-spacing
Hi Jonathan,
You can control which survey questions will appear in the report, under the Analyze tab > View Settings > Set visibility and check/uncheck which questions you want to appear in the survey.
Unfortunately, we don't support customizing the "font,size, line-spacing" of the report at this time. Please submit an enhancement request for this functionality on the ArcGIS Ideas site, ArcGIS Ideas
Hope this helps,
