Michelle, Looks like 3.1.5 has some major issue. My only recomendation at this point is to downgrade to 3.1.4. I am in the middle of some other widget updates and am not sure when I will get back to the eSearch.
<field name="PHOTO_ID" alias="PHOTO" hyperlinkgridfield="true" hyperlinkaliastext="Photo" hyperlinkgridicon="assets/images/i_camera.png"/>
TypeError: Error #1009: Cannot access a property or method of a null object reference. at widgets.eSearch::eSearchWidget/clickSearchRelateResult() at widgets.eSearch::SearchWidgetFloatDG/clickRow() at widgets.eSearch::SearchWidgetFloatDG/__resultsGrid_gridClick() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at mx.core::UIComponent/dispatchEvent() at spark.components::Grid/dispatchGridEvent() at spark.components::Grid/dispatchGridClickEvents() at spark.components::Grid/grid_mouseDownDragUpHandler() at MethodInfo-5341()
<field name="PHOTO_ID" alias="PHOTO" hyperlinkgridfield="true" hyperlinkaliastext="Photo" />
Slade, I am still struggling with why you are experiencing this issue. I have had no other reports of any issue close to this. Can you try and add the new symbology tag to your layers? <symbology> <picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> </symbology>
Andy, This thread is dealing with the Enhanced Search Widget and not the OTB Search Widget. But to answer your question what you are attempting can not be done with out writing code to handle the Query of two specific REST endpoints and then more code to handle displaying the results of both querys.
Chris, It is hard to tell, you might have removed something that is needed in the eSearchWidget.xml file. Can you search your PC for the eSearchWidget.xml file and zip it and attach it for review?
Chris, Seems like you sent me the wrong file (right name and all), but this one is unaltered from the original that is included in the download and does not contain any of your changes.
Jon, You simply forgot to change the <floatorfixed>fixed</floatorfixed> to float.
