「Load a Topology to a Fabric」ツールを使用し、以前に検証および修正されたフィーチャクラス(属性テーブルで1つ選択済み)で、このエラーが表示されます....<\/P>
<\/P>
誰かこれに遭遇したことがありますか。このメッセージは非常に明確で説明的なので、なぜここに来て質問する必要があったのか不思議です...<\/P><\/BODY><\/HTML>
Larry, it is strange that you are seeing this message during use of the Load a Topology to a Fabric tool. Since the Loader is a GP tool, any messages should be going to the GP message log. I'm not sure what would cause this, since I've not seen this message when doing an import. To confirm: the dialog box shows up during the actual loading process?
That message you are seeing would appear if you did something like the following workflow:
As you can tell from these steps they are not directly associated with the Load a Topology GP tool.
Tim, so sorry for the delay, and thank you for yours! Um, yes...it happened while running the GP tool (Load a Topology). I haven't used the tool since then but will try again to see if it happens again. Thanks for the insight.
