How to create a survey that averages the question ratings into one score and pop out an average? Wanting to create a survey thats not done for multiple people thats crowdsourced but single survey.
Currently cannot group questions together to give an average, all items are separated. Any ideas?
Hi Daniel,
Currently the Analyze page does not provide averages of choices - while your choices are numbers, the default behavior is store the data as text. If you use Survey123 Connect, this can be changed when authoring the survey by using the bind:esri:fieldType column; however, the Analyze page will not provide the average for a single choice question.
