私は土地記録のためにArcGISの使い方を学んでおり、PLSS形式で記述された土地エリアを囲むポリゴンを表示する方法があるかどうか知りたいです。例えば、カンザス州のトラクトレコードで土地記述がSE\/4 SE\/4 Section 16 T8S R8Wの場合、その記述されたエリアを覆うポリゴンを作成したいときはどうすればよいでしょうか?<\/P>
<\/P>
ご助力いただけると幸いです。<\/P>
PLSS<\/P>
土地記録<\/P>
土地測量<\/P>
#land management<\/A><\/P><\/BODY><\/HTML>
Hello Shaun,
Below is a simple configuration of our standard Parcel Viewer to locate PLSS divisions and export them to a variety of formats. Still more work to be done on this (including adding quarters and quarter/quarters) but it's a good proof of concept for you.
https://arcgis4localgov2.maps.arcgis.com/apps/webappviewer/index.html?id=ab509ef545b6459d95f5eb83f4f53d42
Locate PLSS Divisions and export screeshots, note that I've pre-populated a search so you can see how it works.
While you're at it, you may also want to see what other solutions for land records we have -
http://solutions.arcgis.com/local-government/land-records
Check out the new Parcel Drafter that lets you enter metes-and-bounds if you need to run out any land descriptions.
http://tryitlive-361356583.us-west-2.elb.amazonaws.com/ParcelDrafter/
Chris
Christopher Buscaglia | ArcGIS Solutions
Esri | 380 New York St | Redlands, CA 92373 | USA
THE SCIENCE OF WHERE™
