I have a #Survey123 survey for which I have developed a report template. When I select a record and run the 'Report Beta' tool then everything works perfectly when I'm using Chrome or Safari, but when I use IE11 (version 11.706.17134.0), then task appears to commence and an hourglass appears and status reads 'Creating...0%', however, nothing changes and it appears that the report generation task hasn't completed..... however... if I log in on another PC or use a different browser (not IE), then the 'Recent Tasks' panel shows that the report (that was started in IE) has indeed completed.
Is there a problem with using IE11 with the 'Report (Beta' tool?
Grateful for any help.
