こんにちは、<\/P>
<\/P>
Land Records Meetup<\/A>のビデオを見ており、これまでのところ、私たちのデータをLGIM parcel fabricに移行するのに非常に役立っています。Bad COGO値が何度も言及されており、それらを削除することが推奨されていますが、彼らは距離だけ(これは理解しています)について話しているのでしょうか、それとも距離と<\/EM>角度の両方についてでしょうか?<\/P><\/P>ありがとうございます!<\/P><\/BODY><\/HTML>
Anna,
Bad COGO values refer to both bearings and distances. What you describe does not happen directly within the parcel fabric editing environment, but it could happen in older legacy systems. Then when importing that data from those systems into the fabric, those "mismatch" values get imported into the parcel fabric. This will result in parcels with a poor parcel misclose.
The Parcel Fabric Quality Control add-in can help to find these cases and, optionally, recalculate the values based on a filter that you set up.
-Tim
How do you determine what a bad COGO value is? That seems like it would be a good amount of analysis work in itself.
The example given in the video is the "back lot problem". A line that was originally drawn in as 100 feet is now broken into two 50 foot sections by an adjoining lot. Kind of like this:
The original line would still have 100 in the distance field and that can throw off the measurement tools in the parcel fabric, as far as I can tell from the videos. I don't have any experience with them yet 😕
