In the survey123 Connect Application, I would like to set the default location for the GeoPoint field. I have the latitude and longitude of the default location and I have entered it under the Map tab under Settings. This is shown in the attached image.
However, It doesn't update the map shown for the question using the GeoPoint field in the final published survey. (I published it after saving the changes in the Settings). Would you suggest any other changes that I can try?
Thank You,
