Can I install the app on my phone but store the .mmpk files on the external storage card? If so how do I point to this new location?
I am using the Quick Report template....maybe there is a setting in the QuickReportApp.qml file?
There is no setting the in the Quick Report template to change the default storage location of the mmpk file, but this can be change in the code in QuickReport/controls/MmpkManager.qml ~80
Thank you,
Erwin
Perfect thanks....will give that a whirl....appreciated.
So if I am correct I think this is the line that I need to modify
var path = [fileFolder.path, "~"+itemName].join("/");
In the MmpkManager.qml file
I added line 13
commented line 15
added/modified line 16
I uploaded and did a make on the project....I downloaded and installed from AGOL and when I went offline it still saved the download to the Phone itself and not the SD Card:
SAMSUNG-SM-J727V\Phone\ArcGIS\AppStudio\Data\QuickReport
Am I missing something?
onReadyStateChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>readyState <SPAN class="operator token">===</SPAN> NetworkRequest<SPAN class="punctuation token">.</SPAN>DONE <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>errorCode <SPAN class="operator token">!=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> root <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN>responseText<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>root<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Mobile Map Package"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> component <SPAN class="operator token">=</SPAN> networkRequestComponent<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> networkRequest <SPAN class="operator token">=</SPAN> component<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createObject</SPAN><SPAN class="punctuation token">(</SPAN>parent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> url <SPAN class="operator token">=</SPAN> rootUrl<SPAN class="operator token">+</SPAN>itemId<SPAN class="operator token">+</SPAN><SPAN class="string token">"/data"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> fileslocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"/mnt/sdcard/ArcGIS/AppStudio/Data/QuickReport/"</SPAN> <SPAN class="comment token">//var path = [fileFolder.path, "~"+itemName].join("/");</SPAN> <SPAN class="keyword token">var</SPAN> path <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>fileslocation<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">join</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"/"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> networkRequest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">downloadFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">,</SPAN> path<SPAN class="punctuation token">,</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN>callback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Has anyone done this before.....I got this to work when I changed it to the C:/Temp/Test on my PC....but still cant get it to my phone storage card. The below first two examples show how I did this to my C Drive.
In the MmpkManager.qml file at the bottom if I change the readonly property url to the below nothing happens...
onReadyStateChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>readyState <SPAN class="operator token">===</SPAN> NetworkRequest<SPAN class="punctuation token">.</SPAN>DONE <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>errorCode <SPAN class="operator token">!=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> root <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN>responseText<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>root<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Mobile Map Package"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> component <SPAN class="operator token">=</SPAN> networkRequestComponent<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> networkRequest <SPAN class="operator token">=</SPAN> component<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createObject</SPAN><SPAN class="punctuation token">(</SPAN>parent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> url <SPAN class="operator token">=</SPAN> rootUrl<SPAN class="operator token">+</SPAN>itemId<SPAN class="operator token">+</SPAN><SPAN class="string token">"/data"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// ADDED</SPAN> <SPAN class="keyword token">var</SPAN> fileslocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:/Temp/tEST/QuickReport"</SPAN> <SPAN class="comment token">// COMMENTED OUT</SPAN> <SPAN class="comment token">//var path = [fileFolder.path, "~"+itemName].join("/");</SPAN> <SPAN class="comment token">// MODIFIED THE ABOVE TO THIS</SPAN> <SPAN class="keyword token">var</SPAN> path <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>fileslocation<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">join</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"/"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> networkRequest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">downloadFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">,</SPAN> path<SPAN class="punctuation token">,</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN>callback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
If I then go to the top of the MmpkManager.qml file and change the below it no uses the C drive and shows the mmpk file through AppStudio when I run the project.
I have to make both changes to get it to work
FileFolder<SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> fileFolder <SPAN class="comment token">// COMMENTED OUT</SPAN> <SPAN class="comment token">//readonly property url storageBasePath: AppFramework.userHomeFolder.fileUrl("ArcGIS/AppStudio/Data")</SPAN> <SPAN class="comment token">// MODIFIED TO THIS</SPAN> <SPAN class="comment token">// THIS WORKS ON THE DESKTOP</SPAN> readonly property url storageBasePath<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"C:/Temp/tEST"</SPAN> property url storagePath<SPAN class="punctuation token">:</SPAN> subFolder <SPAN class="operator token">&&</SPAN> subFolder<SPAN class="operator token">></SPAN><SPAN class="string token">""</SPAN> <SPAN class="operator token">?</SPAN> storageBasePath <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/"</SPAN> <SPAN class="operator token">+</SPAN> subFolder <SPAN class="punctuation token">:</SPAN> storageBasePath url<SPAN class="punctuation token">:</SPAN> storagePath Component<SPAN class="punctuation token">.</SPAN>onCompleted<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>fileFolder<SPAN class="punctuation token">.</SPAN>exists<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> fileFolder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">makeFolder</SPAN><SPAN class="punctuation token">(</SPAN>storagePath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>fileFolder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">fileExists</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".nomedia"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN> Qt<SPAN class="punctuation token">.</SPAN>platform<SPAN class="punctuation token">.</SPAN>os <SPAN class="operator token">===</SPAN> <SPAN class="string token">"android"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> fileFolder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">writeFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".nomedia"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
If I make the two above changes it works....I am then trying to modify that so I can use on my Phones SD Card and nothing works....
My question is am on on the right path? Are there any other modifications that I need to make to the code to get this to work?
I then try this...to get to the storage card
At the top of the MmpkManager.qml
readonly property url storageBasePath<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"/storage/Test"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
At the bottom of the MmpkManager.qml
<SPAN class="keyword token">var</SPAN> fileslocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"/storage/Test/QuickReport"</SPAN> <SPAN class="keyword token">var</SPAN> path <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>fileslocation<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">join</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"/"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> networkRequest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">downloadFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">,</SPAN> path<SPAN class="punctuation token">,</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN>callback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Any one have any thoughts?
Jay,
The path to external storage card on every device and platform can be varied.
The best way to get the path to the external storage card (if present, I am assuming Android?) is by using the StorageInfo plugin from AppStudio AppFramework.
For example like this,
StorageInfo <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> storageInfo <SPAN class="punctuation token">}</SPAN> Component<SPAN class="punctuation token">.</SPAN>onCompleted<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> path<SPAN class="punctuation token">,</SPAN> fs<SPAN class="punctuation token">,</SPAN> dev<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> mountedVols <SPAN class="operator token">=</SPAN> storageInfo<SPAN class="punctuation token">.</SPAN>mountedVolumes<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> mountedVols<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> fs <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>fileSystemType<SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"file system type: "</SPAN><SPAN class="punctuation token">,</SPAN> fs<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> dev <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>device console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"device: "</SPAN><SPAN class="punctuation token">,</SPAN> dev<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> path <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"path: "</SPAN><SPAN class="punctuation token">,</SPAN> path<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The path to the storage card normally starts with "/storage/..." or "/mnt/...
Fantastic...this uncovered I had the path incorrect the whole time....going to give this a shot....
THANKS
OK I added the code below to try and get the path....downloaded to my phone and the results are below.
Note the results are printed 2 times via the For Loop
RESULTS ON PHONE:
pathTV is: /storage/self /storage/self
fsTV is: tmpfstmpfs
devTV is: tmpfstmpfs
urlTV is: /storage/selffile:///storage/self
fileFTV is: /storage/selfundefined
STILL DOES not work.....ANY THOUGHTS????
<SPAN class="keyword token">import</SPAN> QtQuick <SPAN class="number token">2.7</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Layouts <SPAN class="number token">1.1</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Controls <SPAN class="number token">2.1</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Controls<SPAN class="punctuation token">.</SPAN>Material <SPAN class="number token">2.1</SPAN> <SPAN class="keyword token">import</SPAN> QtGraphicalEffects <SPAN class="number token">1.0</SPAN> <SPAN class="keyword token">import</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>AppFramework <SPAN class="number token">1.0</SPAN> <SPAN class="keyword token">import</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>AppFramework<SPAN class="punctuation token">.</SPAN>Controls <SPAN class="number token">1.0</SPAN> <SPAN class="keyword token">import</SPAN> Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime <SPAN class="number token">100.2</SPAN> App <SPAN class="punctuation token">{</SPAN> property <SPAN class="keyword token">var</SPAN> pathTV<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"path"</SPAN> property <SPAN class="keyword token">var</SPAN> fsTV<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fstv"</SPAN> property <SPAN class="keyword token">var</SPAN> devTV<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"devtv"</SPAN> property <SPAN class="keyword token">var</SPAN> urlTV<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"urltv"</SPAN> property <SPAN class="keyword token">var</SPAN> fileFTV<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fileFTV"</SPAN> id<SPAN class="punctuation token">:</SPAN> app width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">400</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">640</SPAN> Text <SPAN class="punctuation token">{</SPAN> anchors <SPAN class="punctuation token">{</SPAN> top<SPAN class="punctuation token">:</SPAN>parent<SPAN class="punctuation token">.</SPAN>top horizontalCenter<SPAN class="punctuation token">:</SPAN> parent<SPAN class="punctuation token">.</SPAN>horizontalCenter margins<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">20</SPAN> <SPAN class="punctuation token">}</SPAN> text<SPAN class="punctuation token">:</SPAN><SPAN class="string token">"StorageInfo Details"</SPAN> font<SPAN class="punctuation token">.</SPAN>pointSize<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">25</SPAN> <SPAN class="punctuation token">}</SPAN> Text <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN>content2 anchors<SPAN class="punctuation token">.</SPAN>fill<SPAN class="punctuation token">:</SPAN> parent text<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"pathTV is: "</SPAN> <SPAN class="operator token">+</SPAN> pathTV <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n fsTV is: "</SPAN> <SPAN class="operator token">+</SPAN> fsTV <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n devTV is: "</SPAN><SPAN class="operator token">+</SPAN> devTV <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n urlTV is: "</SPAN><SPAN class="operator token">+</SPAN> urlTV <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n fileFTV is: "</SPAN><SPAN class="operator token">+</SPAN> fileFTV font<SPAN class="punctuation token">.</SPAN>pointSize<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"green"</SPAN> wrapMode<SPAN class="punctuation token">:</SPAN> Text<SPAN class="punctuation token">.</SPAN>WrapAtWordBoundaryOrAnywhere horizontalAlignment<SPAN class="punctuation token">:</SPAN> Text<SPAN class="punctuation token">.</SPAN>AlignHCenter verticalAlignment<SPAN class="punctuation token">:</SPAN> Text<SPAN class="punctuation token">.</SPAN>AlignVCenter elide<SPAN class="punctuation token">:</SPAN> Text<SPAN class="punctuation token">.</SPAN>ElideRight anchors<SPAN class="punctuation token">.</SPAN>margins<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN> <SPAN class="punctuation token">}</SPAN> StorageInfo <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN>storageInfo <SPAN class="punctuation token">}</SPAN> Component<SPAN class="punctuation token">.</SPAN>onCompleted<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> pathT<SPAN class="punctuation token">,</SPAN> fsT<SPAN class="punctuation token">,</SPAN> devT<SPAN class="punctuation token">,</SPAN> urlT<SPAN class="punctuation token">,</SPAN> fileFT<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> path<SPAN class="punctuation token">,</SPAN> fs<SPAN class="punctuation token">,</SPAN> dev<SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">,</SPAN> fileF<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> mountedVols <SPAN class="operator token">=</SPAN> storageInfo<SPAN class="punctuation token">.</SPAN>mountedVolumes<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> mountedVols<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> fs <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>fileSystemType<SPAN class="punctuation token">;</SPAN> fsT <SPAN class="operator token">=</SPAN> fs <SPAN class="operator token">+</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>fileSystemType<SPAN class="punctuation token">;</SPAN> dev <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>device devT <SPAN class="operator token">=</SPAN> dev <SPAN class="operator token">+</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>device path <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">;</SPAN> pathT <SPAN class="operator token">=</SPAN> path <SPAN class="operator token">+</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">;</SPAN> url <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>url<SPAN class="punctuation token">;</SPAN> urlT <SPAN class="operator token">=</SPAN> path <SPAN class="operator token">+</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>url<SPAN class="punctuation token">;</SPAN> fileF <SPAN class="operator token">=</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>folder<SPAN class="punctuation token">.</SPAN>FileFolder<SPAN class="punctuation token">.</SPAN>folderName<SPAN class="punctuation token">;</SPAN> fileFT <SPAN class="operator token">=</SPAN> path <SPAN class="operator token">+</SPAN> mountedVols<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>folder<SPAN class="punctuation token">.</SPAN>FileFolder<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> pathTV <SPAN class="operator token">=</SPAN> <SPAN class="token function">String</SPAN><SPAN class="punctuation token">(</SPAN>pathT<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> fsTV <SPAN class="operator token">=</SPAN> <SPAN class="token function">String</SPAN><SPAN class="punctuation token">(</SPAN>fsT<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> devTV <SPAN class="operator token">=</SPAN> <SPAN class="token function">String</SPAN><SPAN class="punctuation token">(</SPAN>devT<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> urlTV <SPAN class="operator token">=</SPAN> <SPAN class="token function">String</SPAN><SPAN class="punctuation token">(</SPAN>urlT<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> fileFTV <SPAN class="operator token">=</SPAN> <SPAN class="token function">String</SPAN><SPAN class="punctuation token">(</SPAN>fileFT<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
From this I tried to specify the path in the MmpkManager as follows...
Top of the MmpkManager.qml
FileFolder<SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> fileFolder <SPAN class="comment token">// readonly property url storageBasePath: AppFramework.userHomeFolder.fileUrl("ArcGIS/AppStudio/Data")</SPAN> readonly property url storageBasePath<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"/storage/self/ArcGIS/AppStudio/Data"</SPAN> property url storagePath<SPAN class="punctuation token">:</SPAN> subFolder <SPAN class="operator token">&&</SPAN> subFolder<SPAN class="operator token">></SPAN><SPAN class="string token">""</SPAN> <SPAN class="operator token">?</SPAN> storageBasePath <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/"</SPAN> <SPAN class="operator token">+</SPAN> subFolder <SPAN class="punctuation token">:</SPAN> storageBasePath url<SPAN class="punctuation token">:</SPAN> storagePath Component<SPAN class="punctuation token">.</SPAN>onCompleted<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>fileFolder<SPAN class="punctuation token">.</SPAN>exists<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> fileFolder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">makeFolder</SPAN><SPAN class="punctuation token">(</SPAN>storagePath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>fileFolder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">fileExists</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".nomedia"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN> Qt<SPAN class="punctuation token">.</SPAN>platform<SPAN class="punctuation token">.</SPAN>os <SPAN class="operator token">===</SPAN> <SPAN class="string token">"android"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> fileFolder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">writeFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".nomedia"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Bottom of the MmpkManager.qml
Component<SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> typeNetworkRequestComponent NetworkRequest<SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> typeNetworkRequest property <SPAN class="keyword token">var</SPAN> callback method<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"GET"</SPAN> ignoreSslErrors<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN> onReadyStateChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>readyState <SPAN class="operator token">===</SPAN> NetworkRequest<SPAN class="punctuation token">.</SPAN>DONE <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>errorCode <SPAN class="operator token">!=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> root <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN>responseText<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>root<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Mobile Map Package"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> component <SPAN class="operator token">=</SPAN> networkRequestComponent<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> networkRequest <SPAN class="operator token">=</SPAN> component<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createObject</SPAN><SPAN class="punctuation token">(</SPAN>parent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> url <SPAN class="operator token">=</SPAN> rootUrl<SPAN class="operator token">+</SPAN>itemId<SPAN class="operator token">+</SPAN><SPAN class="string token">"/data"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> fileslocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"/storage/self/ArcGIS/AppStudio/Data/QuickReport"</SPAN> <SPAN class="keyword token">var</SPAN> path <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>fileslocation<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">join</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"/"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> networkRequest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">downloadFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"~"</SPAN><SPAN class="operator token">+</SPAN>itemName<SPAN class="punctuation token">,</SPAN> url<SPAN class="punctuation token">,</SPAN> path<SPAN class="punctuation token">,</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN>callback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">checkType</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">,</SPAN> callback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN>url <SPAN class="operator token">=</SPAN> url<SPAN class="punctuation token">;</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN>callback <SPAN class="operator token">=</SPAN> callback<SPAN class="punctuation token">;</SPAN> typeNetworkRequest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">send</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> loadStatus <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This is weird. The path seems good, what is the make and model of the phone you are testing? OS version?
