That is great to hear Imran, I'm glad my comment was able to assist, even if it was only a little bit
Although I am not positive, from the error it sounds like you have reserved words included with your attribute column names. Try renaming the attributes to include your initials or something like ..."_IKP" at the end of the attribute name you currently have in the table.
I think those columns are columns that Survey123 adds a survey feature service by default - if you go to the item details of this feature service > Settings > is 'Keep track of who created and last updated features.' enabled?
@Carmel Connolly, Thank you very much for your suggestion in solving the problem. Now i'm able to send the survey form to AGOL without any error. What i have done is disabling 'Keep track of who created and last updated features.'
I'm sharing the screenshot of the same.
Mr. Carmel Connolly, You have no idea how desperately i needed a solution for this problem. I am doing a survey as a part of my project related to health and i got stuck with this error. Now, i can go ahead with my work. Once again thank you very much for your valuable suggestion.
Mr. Matthew Duffy, Thank you very much for the immediate response. Although your suggestion hasn't solved the problem; i came to know about reserved words because of your reply and i have used some of them in the name field. Now, i replaced those reserved words. Once again thank you very much for your suggestions.
