Hi all,I have a dataset with only zip codes. I'm trying to geocode but cannot find a coordinate system that will allow me to match to a zip code-level.I see Tom Tom has something, not sure if it's a coordinate system, allowing users to do this, but I do not have access to those files (see attached screen shot).[ATTACH=CONFIG]25339[/ATTACH]Can anyone recommend a solution to geocoding to zip-only level and allowing me to match?Thanks
Thanks much, Joe.I have a shape file for zip codes (Tiger shapfiles), so do I need to add that as a layer on my map first? I was tasked with geocoding this excel list of zip codes (I suppose, basically getting X,Y coordinates and mapping out). I tried geocoding to the .pri coordinate file within the Tiger shapefile but got no matches.
