I am looking for information about printing reports as opposed to individual survey responses, can anyone suggest a resource? Thanks.
Hi Howard,
Currently through the Survey123 website you can print via the Individual Response window which opens when you select a record in the table on the Data tab. Alternatively you can use the Report (Beta) option located in the menu bar above the map to create custom report templates to print survey responses. Currently you can only print one record at a time via the custom report printing, however we do have an enhancement request currently in progress to support batch printing (printing multiple records at once) and also printing to other formats such as PDF.
I have added your comments to the enhancement request.
Regards,
Phil.
