私は小さな自治体で働いており、AMI(Automatic Meter Infrastructure)をGISマッピングと統合したいと考えています。どなたか適切な方向に導いていただけると大変ありがたいです。ありがとうございます。<\/P><\/BODY><\/HTML>
Nathan,
Your best bet would be to use the GeoEvent Extension for ArcGIS Server, which would then allow you to publish out the near real-time AMI data to a feature service.
One of the places that I would check out, are the tutorials/guides for GeoEvent found here:
GeoEvent Extension tutorials—Real-time Data Feeds and Sensors (10.3 and 10.3.1) | ArcGIS for Server
There are a couple really good examples in the tutorial that walk through the ways to create the link between your real-time data (AMI) and a representation of it.
You could also get a 60-day trial of the software if you have a testing environment to load it on to.
Thank you very much for the info. I will check it out. Advice is greatly appreciated.
Sent from my iPhone
Perhaps you can give more detail about what your hoping to accomplish.
