Actually it is possible that the widget he is referencing is a layout widget and not supported by the Flex Application Builder.
now I would like to include the above widget into ArcGIS Viewer for Flex Application Builder 3.1.
I have followed the above steps but no luck. could you please suggest me another alternate.
Uday,Just wanted to confirm if you have looked at: Managing custom widgetsFrom the previous link I mentioned-"Starting with version 3.0, it is possible to add and remove custom widgets from application builder. A dialog box is provided to make adding and removing custom widgets as simple as the click of a button. For more information on adding custom widgets into application builder, see Manage custom widgets."
