buffers
Go to the table of contents in an the MXD your going to use the tool in.
By default the top of the table of contents is called Layers
Right click on Layers and select Properties.
Click on the General Tab. In the middle it will show Units. There will be Map and Display units. Map is what the buffer will be made in.
you're my hero! thank you so much!
