皆さん、<\/P>
低高度で飛行するドローンが撮影した写真を使って地図の可視化を作成することは可能でしょうか。これらの画像はジオリファレンスされており、私たちのArcGISサーバーに保存されています。<\/P>
ありがとうございます!<\/P><\/BODY><\/HTML>
Hi Ramiro - at this time it is not possible to use your imagery in ArcGIS Maps for Power BI. In the near future you will be able to use custom basemaps from your ArcGIS Online organization, which will allow you to get your raster imagery into your maps in Power BI. To prepare for this functionality you'll want to create a basemap with your drone imagery in ArcGIS Online and make it available to your organization. In the future, when you sign into ArcGIS Maps for Power BI with ArcGIS Online credentials you will have the option to use any of the basemaps set up for use by your organization.
If you mean to change the basemap imagery, that would be a no (see Scotts respose). If you mean have points (from xy coordinates) or polys (from AGOL layer) then you could tie your pictures to a URL in your table. However the source would have to sit on a public server. I haven't found a way of displaying pictures on a site requiring credentials, such as sharepoint. That's limiting because we don't want to publicly share our documents for internal Power BI dashboards. BTW the AGOL is a fairly cheap cloud document storage solution, and if you share globally its as good a place to store docs/photos as any. It's unlikely (though possible) that someone will discover your docs. We use AGOL for attachment storage and link it to features on the map. its a little clunky, because we haven't figured out how to read the REST features directly into Power BI (if that is even possible?), so we synch the table with Sharepoint every so often so that the feature table is available to Power BI and displayed as just xy points on the map (they are polys in AGOL, but we don't want to publicly share them).
