I appreciate the response Dominique, unfortunately that will not resolve my dilemma. I have to use a layer list that will always be displayed for the user, allowing them to turn on/off whatever they need. If I created a layer for each units calls by year I would have a layerlist that was entirely too large for the user to look at.
I have writers block on this one - so deep I cannot even provide any code to start with.I have a feature class that contains fields for:UNITS: Emmergency Service VehiclesYEAR: Year of a call the unit went on (4 years are covered)In this feature class there are multiple calls for each unit during each of the years.I have been asked to create a map which a user can select a unit, or multiple units, with a checkbox, and then in a different layer list select the year they wish to view, or multiple years.Example: I have UNIT A, UNIT B and UNIT C turned on (checked) in one list, I then turn on (check) 2010 and 2011 in another list and points populate the map that those units went on during those years.I have the feeling this might be a basic solution, but I cannot find an example. I am still a novice at Silverlight so this is not coming easy. Any recommendations would be extremely appreciated.Thank you
