このプレイス名がgeonet共有リストに見当たりません。<\/P>
既存のgeonetコンテンツをこのHealth and Human Services geonetプレイスにどのように共有できますか?<\/P><\/BODY><\/HTML>
Hope the above snapshots are self-explanatory.
Hello Jayanta,
That's not exactly the correct answer because I do not see "Spaces" in the Choose Location listing. I only see Following, Groups and Projects.
Is that something I can fix or is it a security setting of geonet?
Timothy Hales
I was able to select & share to that space within the "Following" list but no "Spaces" option like you are showing in your slide.
-Bill
You should see the same options as Jayanta as your permissions are the same. Also searching for a place tends to be a little easier than browsing through hundreds of options.
