Am I missing something?
Assign rule Pointmarker_To_FootprintShape
There is no shapes created from the "Get map data" function to apply any rules to.
In the File -> Get Map Data window, check the "Download polygons" box to get building footprints.
Of course I check those boxes. But after it gets the data there are no residential footprints. In later versions it did get all the residential house footprints.
What geographical area are you trying to download? Can you post a screenshot of your settings in the Get Map Data window?
Check SEMCOG's website. They have implemented an Open Data portal with tons of GIS Data include building footprints.
Who is SEMCOG?
How do I download an OSM file form SEMCOG?
The Southeast Michigan Council of Governments (SEMCOG) supports local planning through its technical, data, and intergovernmental resources. The work SEMCOG does improves the quality of the region's water, makes the transportation system safer and more efficient, revitalizes communities, and spurs economic development.
About SEMCOG
Data and Maps
http://maps-semcog.opendata.arcgis.com/
OMG AWESOME
Is this common knowledge!?
SEMCOG is great. Honestly some of the best metadata I've seen. I'm glad I could share it. Is it Common knowledge...I'm not sure. My brother's architecture firm in Detroit wasn't aware of it and until I showed them the light. More and more communities/counties/mpos are implementing Esri's Open Data Portal. I usually check there first and use OSM/Get Map Data as a backup.
I'm in the Detroit Metro area as well..:)
The SEMCOG is only south east Michigan. Is there a site like this for other areas in the USA?
You just have to search wherever your project is. I typically look first for the county with a search term like this - Cook County Open Data Portal GIS and then I'll try the MPO (i.e. CEMCOG) and finally the city.
