Here is the easiest way to fix the problem. Open the Export Map window and put your cursor in the File Name section. Hit the Tab key 4 times to activate the Options button that is hidden (should be right after Cancel), press space bar once to expand the Option section.Kyle
Hola Chicos, Kyle and everyone.
Thanks for your advice. It works.
Diana Eusse
Kyle Gallagher
Thank you thank you very much....It works ( Clip To Graphic Extent option is selected) in Arcmap...
Hi @Kyle Gallagher
It worked, but not completly! The options are shown again, but not "Clip To Graphic Extent".
Any ideia ?
It worked! Thank youuu
I'm having the same problem with arcgis 10.4. Is there another solution ? I hit key tap 4 times, but still have the same problem.
I used the same 4tab, space bar to see the Options for file format export....but still do not see the "Clip to Graphic Extent" either....any updates adding that check box option back in? I am using both arcmap and arcpro....but would like to get this remedied in arcmap.
I have one foot in arcmap the other in arcpro...
1. Press windows key + R
2. Type "regedit"
3. Go to: HKEY_CURRENT_USER - SOFTWARE - ESRI - Desktop(the version you're using) - Export - ExportDIg
4. Double click on ShowOptionsPanel
5. Type "1"
I have Win7 Pro and use the Ctrl+O to toggle the Export Map Options Tab. The underscore O in Options when the tab is available was the key to solving the issue even though at least one a year I forget and have to look it up a txt note on the Desktop to unlock it.
uhhhh after 11 years of your problem I am facing this problem now...it seems like Esri really doesn't like to take user feedback..... I am reading the comment section to find the solution
Hi! I posted a comment with a solution a while back, see if it works:
Solution for Windows 11 users (without editing the Registry):
If display scale is not set to 100 %, this might cause the problem.
Go to Windows settings: System > Display > Scale & layout. Set the scale to 100 %. Expand the options of the ArcMap dialog window. You may change the system scale again after that. Repeat these steps if you accidentally collapse the options again.
You might try this. I helped someone today who had the same problem with Windows 11. The problem was caused by the Windows default value of 150 % for display scale.
As for me, changing the display resolution back to 100% and running ArcMap again solved the issue. I am working on Windows 10.
