Hello,
I am struggling with a projection issue in Arcpad 10.22. In ArcMap I created a shapefile layer of points by digitizing. I then opened arcpad and in a new map added the point layer rather than use ArcPad data Manager. View the two attached screen captures and you can see the huge discrepancy in the Lat/Longs from ArcMap to ArcPad in the Status Bar. Can’t figure why Arcpad shows 377,683+ degrees North when ArcMap correctly shows 86+ degrees South. Am using WGS 1984 Antarctic Polar Stereographic projection. Thanks in advance for any insights
John
