I don't have access to that tool (I only have ArcGIS basic). Try ET Geowizards Polyline to Polygon tool, it does what you need.http://www.ian-ko.com/
For this I just manually split the set up into 4 non-overlapping shapefiles, which was kind of amusing, and ran each to create polygons in a common target polygon shapefile.
