#Import system modules import arcpy from arcpy import env#Workspace env.workspace = "E:\User\MillageCode"#Variables input = "Sales_2006.shp" clip = "EagleHarborSales_temp.shp" output = "Output_temp5.shp"#Clip the Sales_2006 shapefile to the EagleHarborSales_temp shapefile arcpy.Clip_analysis(input, clip, output)#Info print arcpy.GetMessages()
#Import modulesimport arcpy, os, sysfrom arcpy import env#Workspacearcpy.env.workspace = arcpy.GetParameterAsText(0)#Variablesinput = arcpy.GetParameterAsText(1)clip = arcpy.GetParameterAsText(2)output = arcpy.GetParameterAsText(3)#Cliparcpy.Clip_analysis(input, clip, output)#Infoprint arcpy.GetMessages()
"E:\User\MillageCode"shouldn't work, you need \\ instead of \ or append r to the front of the path
Executing: Clip E:\User\MillageCode\Sales_2006.shp E:\User\MillageCode\EagleHarborSales_temp.shp E:\User\MillageCode\Output_temp5.shp #Start Time: Tue Jul 16 07:35:46 2013Reading Features...Cracking Features...Assembling Features...Succeeded at Tue Jul 16 07:35:46 2013 (Elapsed Time: 0.00 seconds)
