Hi Tim, Are you saying I can load the "esri/layers/FeatureLayer" module and switch "ArcGISDynamicMapServiceLayer" to "FeatureLayer" when defining the variables for the service? I'm not having luck doing that.
Greg,this works with every type of layer. Shouldn't make a difference if you use feature layers.Tim
Nick,I am using this https://developers.arcgis.com/javascript/jssamples/widget_legendvisible.htmlTim
