I am similarly having issues with the DEM reconditioning tool. I have tried all of the suggested solutions, including those found in the Arc Hydro Problem Solvers thread. Any help on this issue would be greatly appreciated!
Your raster's coordinate system is:
USA_Contiguous_Albers_Equal_Area_Conic_USGS_version, WKID: 102039 Authority: ESRI
Your polyline layer coordinate system is:
GCS_North_American_1983, WKID: 4269 Authority: EPSG
Your first step is to choose the coordinate system for your project and reproject the data to the same coordinate system.
Mark
Yup, that fixed it! Thank you!
I downloaded your data. I projected the streams layer to the same coordinate system a you dem and changed the project on the data frame to that same projection. I ran the dem reconditioning using the dem and the reprojected streams dataset and it ran without error.
