Hi!I detected issue with incorrect visualization of PictureMarkerSymbol. Url property is image data encoded in base64. Behavior of this issue undefined. Condition for search crashed picture: many objects with large sizes, arcgis js api 4.10, 4.11I created example on jsfiddle https://jsfiddle.net/catcherholms/dmp1z387/136/Issue visualization I attached.
I had the same issue with this last summer: Feature Layer incorrect rendering with webgl rendering and picture marker symbols and it was resolved with 4.9.
A couple of bug reports were filed about it:
#BUG-000115988 Picture Marker Symbols in Feature Layer are unable to display with WebGL enabled when imageData of the symbol stored at REST Endpoint is lengthy.
#BUG-000115991 Picture marker symbols in FeatureLayer with WebGL enabled display as jumbled when using more than 10 unique value categories to symbolize points.
You may want to open a support ticket with Esri and have them look at this again if you're seeing the same issues because it looks like the exact same thing we were experiencing with 4.8.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
