Is this a building scene layer? If so, building scene layers are not supported until portal 10.7.
thanks,
Andrew
Hi Andrew,
it's not building scene layer. It working fine when I publish it to AGOL. but I what it in portal
I have tried to publish directly from ArcGIS Pro . I get below error.
Error - ERROR 999999: Something unexpected caused the tool to fail. Please refer to the error help for potential solutions, or contact Esri Technical Support http://esriurl.com/support.Error - Failed to execute (Manage Scene Cache).Informative - Failed at Tuesday, May 19, 2020 2:48:25 PM (Elapsed Time: 11.33 seconds)Error - Failed.
Thank you
Divya
To get the quickest resolution I would recommend reaching out to technical support. It appears to be an issue with the Tile Cache data store which a support analyst will be able to diagnose and resolve over phone/screenshare session.
Thank you. I will contact the support team
Kind Regards,
