I need some help getting the stock Web Appbuilder 2.0 to print with a header, layout and layer list and scale. I am not supper familiar with java. So if anyone can guide me through to modify the Print.js, i would really really appreciate it.
i would like it to look like the the attached.
I do not have ArcGIS Web Server.
when you say
Do you mean that you do not have your own ArcGIS Server and you are only using AGOL?
my bad, yes i don't have ArcGIS Server.
I am only using AGOL.
That's bad then as you need to setup a custom print service on your ArcGIS server that uses custom print layouts to accomplish what you are after.
I was trying to use Print Plus which worked fine in Web Appbuilder but once i download and placed the app in wwwroot and launched i get an init.js:89 Error: Unable to complete operation. So i was looking to see what other options i had. Thanks for the info and reply.
