I'm new here and I have a big problem with clipping - the same is appearing after intersect. I have a line which is going through one place to be cut in (polygon in the irregular shape)- when I do clip or interesect - it becames out as multiline. And when I explode it, it becames a many small lines, but I want them just to be 2 single parts, not so many single parts. The demonstration on the jpg Could anyone help me? I would be really grateful.
Edit: Reexamined your line data and realized the breaks are not due to the polygon shapes, but due to the lines crossing each other. To fix that add a Dissolve at the end of your current process with the Multipart option unchecked. Set the unique attribute case fields of the Dissolve to be equal to the FID of the original line and the FID of the originally intersected parcel (probably using Intersect in your prior steps is better to use than Clip, unless Clip also transfers polygon attributes to your lines like the Intersect tool does). That should eliminate all line breaks due to intersection with other lines except self intersections of the original lines where they formed branches. That is a special case requiring additional handling, but I won't cover that unless you confirm it affects your data.
Thank you soooo much for an answer. It helped a lot with dissolve.
