Good Afternoon,
Is there a way to change the navbar color in the web viewer? I have all my other colors figured out, but the dark gray doesn't go with my color scheme.
Nathan
Hi Nathan
It's not possible to change the colour of the navbar, however you can hide it using the hide=navbar URL parameter.
Please find more info on URL parameters here: https://community.esri.com/groups/survey123/blog/2019/02/06/survey123-tricks-of-the-trade-web-form-url-parameters
Best,
Jim
cc: Ruth Jiateng Xu
Would this be possible with the new Survey123 Web API they were discussing at the UC?
Apologies for the late reply. Changing the navbar colour is not possible with the web app API (although hiding it is).
You can find out more about the API here: https://community.esri.com/groups/survey123/blog/2020/03/05/introducing-the-survey123-web-app-javascript-api
Could you not apply CSS that would do that through the Web App JS API?
Hi Nathan,
The Web App JS API can only control the style of the form area, not the Nav bar. Would you mind raise an Idea here? ArcGIS Ideas
Jody Zheng Liu
