Just for reference, may be wrong�?�Data Type: IFeatureLayer.DataSourceType �?�Feature Class: IFeatureLayer.featureClass �?�SERVER: IFeatureLayer.featureClass->Idataset->IpropertySet->GetProperty("Server") �?�INSTANCE:IFeatureLayer.featureClass->Idataset->IpropertySet->GetProperty("Instance") �?�Location:IFeatureLayer.featureClass->Idataset->IpropertySet->GetProperty("database") �?�AUTHENTICATION_MODE:IFeatureLayer.featureClass->Idataset->IpropertySet->GetProperty("AUTHENTICATION_MODE") �?�VERSION:IFeatureLayer.featureClass->Idataset->IpropertySet->GetProperty("version")Regards,Bing
You can use pfeatureclass.FeatureDataset if the feature class is stored inside feature dataset. if not use below statement to convert ifeatureclass to idataset and then get the connection properties.IDataset pdataset = pfeatureclass as IDataset;
