Hello folks,I need help with the proper syntax. I'm sure it's easy I just cant get it. Basically it's telling me that the syntax for my return value, Str(!SHIELD_VAL!), is invalid. I'm using a field calculator to run a check on field HWY_Type and given certain values, it will populate field FEDROUTE with the value of SHIELD_VAL. Any help would be appreciated.Thank youAlandef FedRoute(tvalue): value = tvalue if value == 'INT': return Str(!SHIELD_VAL!) elif value == 'US': return Str(!SHIELD_VAL!) FedRoute(!HWY_Type!)
