I created a buffer around point features. Now I want to combine the two into one feature class still keeping the point or centroid visible since my buffer was 200'. Is this possible?
I said forget it and simply added that feature layer to the gdb and will carry it along that way.
https://community.esri.com/thread/162591
Maybe I just join and replace the point with the buffer polygon?
Not following. I want the buffer ring visible as we used Quick Capture for transmission line patrol. Depending when they snapped the issue, it could be between two different structures. More or less, I would like the buffer tied to that point to disappear with the same definition query.
Think it's not possible, but why not buffer your points again with a very small distance?
