When linking from web application to survey 123 using hyperlink in the pop up window, is it possible to just open survey 123 without open a new tab? Thanks.
Hi Ying Zhang
Are you launching the survey in the field app or the web app?
Jim
Yes. I launched it in the web application hosted at ArcGIS Online. Thanks!
Thanks Ying Zhang - I am not aware of a way to make the survey open in the Survey123 web application in the same window as the source ArcGIS Online web mapping application, other than to drag-and-drop the link onto the same tab in the browser's title bar. It might be worth asking a question on the Web AppBuilder for ArcGIS Community to see if there are any ideas.
Best regards,
