こんにちは、 <\/P>
Utility Isolation Trace<\/A> をダウンロードして、サンプルデータで設定しましたが、非常にうまく動作しています。しかし、異なる投影法 WGS1984 UTM37 を使用したデータベースに私のウォーターネットワークを追加しようとすると、動作しません。<\/P><\/P>このアプリケーションを自分のジオメトリックネットワークに設定することは可能かどうか教えてください。<\/P>mmiller-esristaff<\/A>、どうか助けてください。<\/P><\/BODY><\/HTML>
<\/P>
Using your data, I was able to get it to working by changing the InputeGDB and Output Coordinate System(2) in the model. I set Output Coordinate System(2) using the feature dataset in the GDB you provided.
Thanks for answer dear Michael
No you sample data is working well, but i want add my data from sql SDE data base, my features is in different projection wgs1984 utm37 and it is problem, that i could not configured GP trace tool with my projection.
when i am executing gp tools error is same that output coordinate system is error and unknown extent.
i need configuret GP model builder, how i can configured i need some manuals
I am attached my water geometric network if you can please check it and can you help me configure GP Isolate Trace?
ERROR LOG
ERROR 999999: Error executing function.invalid extent for output coordinate systemFailed to execute (Project Flags).Failed at Thu Sep 29 22:46:34 2016 (Elapsed Time: 0.20 seconds)Failed to execute (IsolationTrace).Failed at Thu Sep 29 22:46:35 2016 (Elapsed Time: 1.38 seconds)
What is not working? Are the flags being snapped? Sometimes you need to delete and re-add the featureset inputs. Did you adjust steps that project the data to your local coordinate system? Also, try deleting the Trace Geometric Network tool and re-add to ensure it is looking at the correct data.
