Hi Julie, did you make sure to download the developer download and follow all these instruction: GitHub - Esri/playlist-storytelling-template-js: A storytelling template that organizes point data sets from a CSV file …? The error you're getting appears that you never ran "bundle install" or that you have not installed ruby or the bundle installer appropriately. If you're on windows, you should also make sure you are using a command line program that provides access to the ruby commands. You should be able to run "ruby -v" and "bundle -v" to see the version numbers of each program installed.
Looks like this one still works: http://links.esri.com/storymaps/numbered_marker_symbols.
Hello,
Both the links don't work for some reason. Is the zip folder still available for download ? It says the site is down .
Julie
(edited to remove old links)
Thank you both Flo and Stephen for your replies.
I think I'm still confused on where to run what. Am I supposed to setup project folder (run 'bundle install', 'npm install -g grunt-cli', 'npm install') in the GitHub location or where I cloned the project?
I tried both environments...but none of them seem to work when I got to 'bundle exec middleman' :
Another dumb question please... am I supposed to modify the codes and do my edits after running 'npm install' but before running 'bundle exec middleman'?
Thank you tremendously again!
Emily
Also, make sure you are running these commands from within the project directory that contains the playlist files. Here’s a trick to get there easily: http://lifehacker.com/5989434/quickly-open-a-command-prompt-from-the-windows-explorer-address-bar
Looks like you are not in the github-shell? Depending on where you have installed github it should show somethihng like: C:\Users\...\GitHub>
You can start the Git-Shell directly from the start-menu or in Git via right-click on the repository where you saved the files of the dev-version.
Stehpen,
Thank you very much for your quick reply. I've downloaded the js developer version of the Playlist app, increased the 'maxAllowablePoints' variable from 99 to 700 on line 19 from the MapConfig.js file (source > app > javascript > playlist > config > MapConfig.js), and updated the webmap ID and other minor things from the index.html file (deploy > index.html). But I still cannot link them together and make the two files talk to each other? The webapp result still gives me up to 99 features. I'm sorry that I'm not a developer, and I've followed the instructions and downloaded all the needed files (Git, Ruby, Ruby Dev Kit, Node) many many times, but I'm still stuck and sort of confused from here on:
and it gave me this error message from the Git Shell commend prompt:
Thank you very much for your time here and any help is greatly appreciated!
Sincerely,
A similar issue regarding the playlist template has been discussed here:
How to use simple markers to show six categories?
Emily,
The first thing you'll need to do is make sure you are using the developer download of the Playlist app. Instructions for setting up your computer for testing your app, building it for production, and source code are available here: Esri/playlist-storytelling-template-js · GitHub.
After you have added the additional photo icons to the correct folder, open up the MapConfig.js file (source > app > javascript > playlist > config > MapConfig.js). On line 19 you can increase the 'maxAllowablePoints' variable. Then make sure you build you app for production before deploying to your server.
Hi Stephen,
Would you mind to pinpoint exactly where to modify the Playlist codes in order to allow for more than 99 points please? I've put all the extended numbered marker symbols that Rupert created in the same folder as the rest of 1-99 numbered icons by color. But still can't find where to modify the codes to include them.
Thank you very much in advance!
And here's an additional zip file of marker symbols that may be useful. Several authors have made additional marker symbols and kindly shared them with us.
