UPDM2016 データモデルでは、単一の Valve 層があります。<\/SPAN><\/P><\/P>メインライン用のインラインバルブとサービス用のカーブバルブの両方を Valve 層に一緒に保存する必要がありますか、それとも別の層がありますか?<\/SPAN><\/SPAN><\/P><\/BODY><\/HTML>
Hi Jordan,
The intention of the Valves featureclass in the UPDM 2016 Edition was to store all controllable valves regardless of their installation location. But, it is important to remember that UPDM is a data model template, it is not a requirement. Every gas utility has unique data management requirements. If your unique data requirements lead you to conclude that the curb stop valves should be stored in a separate featureclass, then please do that.
If you do not have a strong business requirement to separate the distribution main gas valves from the service line curb valves, then my advice would be to keep them in the same featureclass to reduce the number of database queries required on your standard map views every time you pan, zoom or edit. Reducing the number of featureclasses used to store your assets is a proven method for improving map redraw performance and the scalability of your Geodatabase..
Tom DeWitte
Esri, Inc
Technical Lead - Natural Gas Industry
