Hello,I have orphaned records in the SDE repository tables (e.g. GDB_OBJECTCLASSES) which I cannot see from ArcCatalog any more. I tried to do what is written herehttp://support.esri.com/en/knowledgebase/techarticles/detail/34050create the table with SQL (Oracle), I cannot create it in ArcCatalog as the table name exists;but I cannot see the table from ArcCatalog afterwards to delete itWe have ArcSDE 9.3, and I use ArcCatalog 10.1I tried as well to delete the table with ArcSDE 9.3 client sdetable -o delete, but the table name still remains in the SDE repository tablesextract from prerequisite check for upgrading SDE (although it is a warning)
Checking dataset (GISPRD.A4).
Table (GISPRD.A4) was found in GDB_ObjectClasses, but does not exist in the database. Skipping.
DBMS table not found [GISPRD.A4][STATE_ID = 19914]
The index passed was not within the valid range.
Any help ?ThanksHilde
